Siebel Order Management Guide Addendum for Communications > Employee Asset-Based Ordering > Defining Component-Level Commitments > About Penalty Component Charges for CommitmentsThis topic shows the interactions of Commitment flag settings and Apply Component Charge flag settings when promotion components are disconnected. When the Commitment check box is selected, it indicates that disconnecting the component also disconnects the promotion. When the Apply Component Charge check box is selected, it adds the penalty for this component when the promotion is disconnected. The following tables illustrate the effects of the various combinations of settings for these check boxes for a promotion with components. Table 9 shows the promotion, its components, the Commitment flag and Apply Component Charge flag settings for each component, and the penalty disconnect charges for the promotion and each component. Table 10 shows the itemized penalty amounts and the total penalty amount for disconnecting each component, resulting from the Commitment flag and Apply Component Charge flag settings for those components. The columns numbered 1 through 5 represent the penalties from Table 9. |
| Siebel Order Management Guide Addendum for Communications | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
