Siebel Order Management Infrastructure Guide > Data Validation Manager > Process of Administering Data Validation Rules > Activating a Data Validation Rule SetThis task is a step in Process of Administering Data Validation Rules. The final step in administering data validation rules is to activate the rule set. Only then can it be executed by the Data Validation Manager business service. After you have added and defined all rule set arguments and rules, activate the rule set. After you activate the rule set, it becomes read-only and can not be edited. You can only define arguments and rules for validation rule sets that have a status of In Progress. If you want to revise an existing rule set, see Revising an Existing Validation Rule Set.
| Siebel Order Management Infrastructure Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
