Siebel Order Management Infrastructure Guide > Data Validation Manager > Process of Administering Data Validation Rules >
Defining Validation Rule Actions
This task is a step in Process of Administering Data Validation Rules. The Data Validation Manager business service can perform a sequence of actions when a rule expression is evaluated to be FALSE. Each action can be set to update a business component in the active business object or to execute a business service. Each action has a sequence number. Data Validation Manager executes the actions in ascending order of their sequence numbers. To define a data validation rule action
- Navigate to Administration - Data Validation, and then Rule Sets view.
- In the Validation Rule Set list, select the rule for which you want to define an action, and drill down on the Name hyperlink.
- Click the Actions view tab.
- In the Actions list, add a new record, and complete the necessary fields. Some fields are described in the table that follows.
Sequence # |
Identifies the numeric sequence of this rule in the rule action. The application executes actions in numerical order based on this number. |
Type |
Determines whether the action is to update the current active business component or execute a business service. Can either be Business Component or Business Service. |
Business Component |
Name of business component which you want to update. This field is editable only when Type is set to Business Component. |
Business Service Name |
Name of the business service you want to invoke. This field is editable only when Type is set to Business Service. |
Business Service Method |
Method of the business service you want to invoke. |
Business Service Context |
Name - value pairs which you can use to pass certain values as input arguments to the business service. For example, "input argument 1", "value 1", "input argument 2", "value 2". |
For each action record of type Business Component, enter the field and value information as described in the table that follows.
Field |
Name of the business component field you want to update. |
Value |
Value with which you want to update the business component field. This value must be a constant and cannot be an expression. |
