Siebel Order Management Infrastructure Guide > Copy Service > Copy Service Methods > LoadInstanceFromBC MethodThe method loads the instance from the business component and pushes it into an instance. If SourceInstance is specified, the new instance is created by cloning the source instance and positioning it on the same row ID. Alternatively, BusObj, BusComp, and a search specification can be used to define the new instance. The instance business component loaded must not have a parent defined in the BusObj. Arguments |
Siebel Order Management Infrastructure Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
