Siebel Order Management Infrastructure Guide > Copy Service > Copy Service Methods >
SetFieldValueFromInstance Method
The method sets the field value to an instance.
Arguments
Argument
Description
InstanceName
[in] ISS business component instance name.
FieldName
[in] business component field name
BusCompName
[in] Used to specify a business component other than the instance business component, if necessary. (Optional)
FieldValue
[in] Field value.
GetLOVValue
[in] LOV Type. If defined, the FieldValue is the LOV language-independent code. The actual field value will be the language-dependent display value as defined by LOV Type or Language independent code. (Optional)
Siebel Order Management Infrastructure Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
