Siebel Order Management Infrastructure Guide > Data Transfer Utilities Business Service > Example of Defining Data Maps to Use with the DTU >
Finding the Data Map Object
You must find the data map object where the header, line items, and XA are mapped. To find the data map object
- Navigate to the Administration - Application screen, then the Data Map Administration view.
- In the Data Map Object list, select the record named QuoteToSalesOrder.
The components of this data map object, including Header, Line Item, and XZ, appear in the Data Map Component list, below the Data Map Object list.
