Siebel Order Management Infrastructure Guide > PSP Engine > Row Set Transformation Toolkit Methods >
Aggregate Method
The Aggregate method calculates the sum, average, minimum, maximum, or count of subgroups of the input row set. Arguments
Context |
Optional. Property set of variables shared across all rows. |
Row Set |
The set of rows to process. |
Output Row Set |
Output Row Set is always created and contains the aggregation results. Each row contains the Group By fields plus the Aggregate Fields (example: Price List ID, Product ID, Qty). For the Count aggregate type, the output row contains the Group By fields plus a field called Count. |
Process Condition |
A Boolean condition that is evaluated to determine whether to process each row. |
Aggregate Type |
Sum, Avg, Min, Max, or Count. |
Aggregate Field |
The field to aggregate (example: Qty). Required for all types except Count. Multiple fields can be aggregated by specifying a comma-separated list of field names. |
Group By |
Optional. A comma-separated list of row field names. Defines the groups of aggregates. (Example: Price List ID, Product ID). |
Example
Figure 21 shows an example of arguments for a PSP procedure step named Sum Product Quantity, which calls the Aggregate method.
Figure 21. Example of Arguments for Aggregate Method
