| Siebel Order Management Infrastructure Guide > PSP Engine > Row Set Transformation Toolkit Methods > Split Method
 The Split method splits an input row set into two output row sets by evaluating a condition for each row.  Arguments
    | Context | Optional. Property set of variables shared across all rows. |
    | Row Set | The set of rows to process. |
    | Condition | A Boolean expression that references {Context} and {Row} field values. |
    | On True Row Set | The row set to which rows are moved if Condition evaluates to True. |
 ExampleFigure 32 shows an example of arguments for a PSP procedure step named Inclusive Eligibility, which uses the Split method.
Figure 32.	Example of Arguments for Split Method
