| Bookshelf Home | Contents | Index | PDF |    |
| Siebel Order Management Infrastructure Guide > PSP Engine > Components of the PSP Engine > PSP, Siebel Workflow, and Siebel ToolsSiebel Workflow—the application you use to define, manage, and enforce your organization's business processes by creating workflow processes—is also the application you use to create, edit, and execute PSP procedures. Siebel Workflow's Process Designer resides in Siebel Tools. NOTE: Siebel Workflow is also known as Siebel Business Process Designer, which is the configuration interface and the administrative interface for Siebel Workflow. You configure PSP procedures and their controller workflows from the Workflow Process object, a top-level object in the Object Explorer within Siebel Tools. In this way, you use the Process Designer to enter transforms for PSP procedure steps as input arguments. For more information about Siebel Workflow, see Siebel Business Process Framework: Workflow Guide. For more information about configuring PSP procedures, see Configuring PSP Procedures. |
| Siebel Order Management Infrastructure Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
