Siebel Order Management Infrastructure Guide > Service-Oriented Architecture > Web Services for Customer Order Management >
Web Services in Version 8.1
This topic describes the new, modified, and consolidated web services to support release 8.1 of the software:
  • Table 2 lists the Web services that are new for customer order management.
  • Table 3 lists the new self service Web services that were added for customer order management.
  • Table 4 lists the new Communications, Media, and Utilities (CMU) Web services for customer order management.
  • Table 5 lists the Web services that were modified for customer order management.
  • Table 6 lists the Web services that have been consolidated for customer order management.
New Web Services
Table 2. New Web Services for Customer Order Management
Type
Web Service Name
Description
Catalog
Get Categories
Retrieves a list of all available product categories in a single Web service interaction.
Publish Catalogs
Retrieves all catalog objects (categories, products, attributes, attribute domains) for a given catalog including private catalog objects based on current catalog access control, and eligibility enforcement options.
Shopping Cart
Price Lists
Gets all active price lists for a given context.
Order Detail
New UI data service (UDS) based on Quote and Order Web services that activate and return only the information (fields) that you requested.
Quote Detail
Quoting
Promotion
Get Promotion
Gets commitments for a given promotion asset.
Modify Promotion or Asset
Upgrades or migrates a promotion instance to another promotion. Supports promotion upgrade or downgrade process from an external application.
Modifies a promotion or asset item from an external application through the modify asset Web service.
New Self Service Web Services
Table 3. Self Service Web Services Added for Customer Order Management
Description
SelfServicePostLogin
Loads the logged in users responsibilities, contact details and primary account. If the primary account is null, loads the root account of the logged in user's contact.
SelfServiceRegistration
Performs the following actions for user registration:
  • Creates a user
  • Creates a contact
  • Creates an account, if required
  • Assigns responsibilities
  • Triggers approval process, if applicable
This Web service also performs the reset password and update password transactions.
SelfServiceContact
Allows you to insert, delete, update, and query a contact, contact details, and the accounts associated with a contact.
SelfServiceAccount
Allows you to insert, delete, update, and query accounts, account addresses, and contacts associated with accounts.
SelfServiceAccountRootPath
Queries the account hierarchy details of the requested account.
SelfServiceAllAccountsList
Queries accounts and account details.
SelfServiceUser
Retrieves user details and user responsibilities.
SelfServiceWebSite
Allows you to insert, update, delete, and query the Self Service site and its details.
OrderDetailWebService
Queries Order header, Order Line, Order Payments, Order Approval, and Shipment details.
SelfServiceSmtpEmail
Send an email using the Outbound Communications Manager business service.
SelfServiceTemplateRule
Queries the Self Service Site template rules.
SelfServiceTimeZone
Queries the time zone and time zone translation details.
SelfServicePaymentHistory
Gets the payment history for a contact or account.
SelfServiceAccountBillingProfile
Performs Insert, Delete, Update, and Query on the accounts billing profile.
SelfServiceAddress
Gets the Address details for a particular account or contact.
SelfServiceResponsibility
Queries responsibilities.
New Communications, Media, and Utilities Web Services
Table 4. New CMU Web Services for Customer Order Management
CMU Web Service
Description
CatalogWebService
Equivalent to the Publish Catalogs Web service.
Equivalent to the Order Detail Web service.
SelfServiceAccount
Equivalent to the SelfServiceAccount Web service.
Equivalent to the SelfServiceAllAccountsList Web service.
Modified Web Services
Table 5. Web Services Modified for Customer Order Management
Web Service
Description
PromotionWebService
The following methods have been added:
  • Promotion Commitments
  • Upgrade Promotion
QuoteWebService
Allows you to insert, update, query, and delete the quote header, quote item, and quote payments.
ProductConfigurator
To support release 8.1 of the software, updates the Web service:
  • To meet all new requirements
  • To fix any issues found
Consolidated Web Services
Table 6. Consolidated Web Services for Customer Order Management
Web Service
Description
QuoteCheckOutWebService
This is the Submit Order Web service that invokes the QuoteCheckOut workflow. The workflow consolidates the submit order functionality, and the credit card validation process.
QuotingWebService
This Web service is used to save a quote, and it invokes the Web Channel Quoting Workflow. This workflow consolidates the following processes:
  • Run the eligibility and compatibility workflow
  • Re-price the quote
  • Calculate delta for ABO quote
  • Perform promotion instance check
  • Calculating shipping charge
  • Calculate Tax
This is the self service registration process, and it invokes the SelfServiceRegistration workflow. It consolidates the following processes:
  • Create a user
  • Create a contact
  • Create an account, if required
  • Assign responsibilities to the user
  • Trigger approval process, if applicable
SelfServicePostLogin is invoked after a user logs into the self service application, and it invokes the SelfServicePostLogin workflow. It consolidates the following processes:
  • Load contact details and responsibilities
  • Load primary account id and root account details
Siebel Order Management Infrastructure Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
