Siebel Order Management Infrastructure Guide > Signals > Creating Signal Actions > Modifying Signal Properties for Signal ActionsSignal properties are similar to user properties on repository objects. Signal properties are name-value pairs used to configure processing. In this release, the only supported use of signal properties is to provide a CanInvoke check. NOTE: For some signals (for example, the QuoteAndOrderValidate signal), the CanInvoke property for the signal can cause related buttons to be disabled. Removing the property, however, results in enabling the related button. To modify signal properties for a CanInvoke check
Example of Signal Properties Settings for a CanInvoke CheckAn example of the fields set for a CanInvoke check is listed in Table 8. NOTE: If CanInvoke logic exists for a specific Mode, it overwrites the CanInvoke logic defined for the mode Any. In the example above, using Quote mode, the CanInvoke logic used will be |
| Siebel Order Management Infrastructure Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
