Siebel Order Management Infrastructure Guide > PSP Waterfall >
PSP Waterfall Business Service Methods
The PSP Waterfall business service provides the methods described in Table 27.
Table 27. PSP Waterfall Business Service Methods
ShowWaterfallPopup |
Name = Popup Applet Name Value = the name of the waterfall popup applet Example: "Quote Line Item Waterfall Popup List Applet" |
Display the waterfall pop-up for the current line item. |
SyncToDB |
See SyncToDB Input Arguments |
Generate waterfall records for the current quote, order, or agreement and write them to the database. For more information, see Saving Waterfall Data. |
The SyncToDB method provides the input arguments described in Table 28. NOTE: You may prefer to use SyncToDB in a signal, rather than directly in a command, for synchronizing waterfall data to the database. If so, use the guidance provided in Saving Waterfall Data.
Table 28. SyncToDB Input Arguments
Pricing Output Row Set Type |
String |
RowSet |
Waterfall Data Map Object |
String |
Quote Waterfall Data Map Object |
Waterfall Name Field |
String |
Name |
Waterfall Parent Id Field |
String |
Item Id |
Waterfall Parent Id Variable |
String |
ID |
Waterfall Signal |
String |
PSPWaterfallAll |
Waterfall Synch Process |
String |
PSP Waterfall Synch to DB Workflow |
Waterfall Sequence Number Field |
String |
Sequence Num |
