Siebel Public Sector Guide > Administering Benefits Cases > Process of Configuring Benefits for Cases > Setting Up Benefits ProgramsAdministrators can set up benefits programs, associate benefits with those programs, and associate products with those benefits. The preconfigured Siebel Public Sector application includes some setup benefits programs. Before you can associate products with benefits, you must set up the products on the Administration - Product screen. For more information, see Siebel Product Administration Guide. If you use the Oracle Policy Automation rulebase to calculate benefits, then make sure that the benefits programs and associated benefits that you set up in Siebel Public Sector also exist in the Oracle Policy Automation rulebase. The row Ids for the benefits programs in Siebel Public Sector are used to create the benefit plans in the Oracle Policy Automation rulebase. Table 11 shows the benefits programs and benefits for the preconfigured, sample rulebase for Oracle Policy Automation. For more information, see About the Sample Rulebase. In the List of Values view of the Administration - Data screen, administrators can edit the available values for program codes, benefit codes, and transaction codes to include the appropriate values for your organization. Table 12 shows the Type field value in the List of Values view for each of these codes. For more information about editing LOVs, see Siebel Applications Administration Guide. If you select the Inactive Flag field of a program or benefit in the Program Benefits Administration view of the Administration - Case screen, then users cannot select the program or benefit for a benefits case. This task is a step in Process of Configuring Benefits for Cases.
| Siebel Public Sector Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
