Siebel Public Sector Guide > Administering Benefits Cases > Process of Configuring Appeal Cases > Setting Up Format in Snapshot Files for Appeal CasesWhen users create an appeal case, a snapshot file is automatically created in the Attachments view for the evidence record of that case. This snapshot file contains the field values for the original case, for the active benefit plans that are associated with that case, and for the benefits that are associated with those benefit plans. NOTE: It is recommended that you make sure that BIP reports function correctly in your environment before you set up a BIP format for the snapshot file. This task is a step in Process of Configuring Appeal Cases. If Oracle Business Intelligence is not integrated with Siebel Public Sector, then administrators can set up an XML format for this snapshot file. To set up the format in snapshot files for appeal cases
Setting Up Format for BIP ReportsIf Oracle Business Intelligence is integrated with Siebel Public Sector, then administrators can set up a BIP (Business Intelligence Publisher) format for this snapshot file. BIP formats include PDF, HTML, and Microsoft Word. |
| Siebel Public Sector Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
