Siebel Remote and Replication Manager Administration Guide > Configuring the Remote Client > Process of Configuring Encryption and Authentication for the Remote Client >
Creating Accounts and Passwords
This task is a step in Process of Configuring Encryption and Authentication for the Remote Client. You must create an account for each client to authenticate a remote client when it synchronizes. The authentication method you choose determines the account you must create. To create accounts and passwords
- Create an account and password according to the type of authentication you use. Use values from the following table.
AppServer authentication |
Create a user account on the Siebel Server for each remote client:
For more information, see How the Change Password Functionality Affects Authentication |
Database authentication |
Create a database account and password for each remote client. |
Siebel authentication |
Do the following:
- Access the Mobile Clients view of the Administration - Siebel Remote screen, and then set the password for each remote client.
- Communicate the password to the user so this user can synchronize with the Siebel Server.
SecurityAdapter authentication |
Create the accounts and passwords that your third party authentication system requires. For example, it might be necessary for you to create records in an LDAP or ADS folder. |
No authentication |
Do not create accounts or passwords for authentication. |
If you use the change password functionality on the remote client while connected to the Siebel Server, then Siebel Remote modifies the server password and stores it in a table that is specific to the server database, and not in a Siebel table. In this situation, the remote client is not synchronized with the local database. The user must continue to use the old user password to access the local database until the next time Siebel Remote reextracts the node. Summary of Accounts, User IDs, and Passwords That Siebel Remote Uses
Table 11 summarizes the accounts, user IDs, and passwords that Siebel Remote uses.
Table 11. Summary of Accounts, User IDs, and Passwords That Siebel Remote Uses
Password, User ID, or Account |
Local Database Password |
Maintains different credentials to access and synchronize the local database. For more information, see Setting the Local Database Password. |
User ID for the Local Database |
For more information, see Siebel CRM Version 8.0 Modifications to User IDs and Passwords for Local Databases. |
Local DBA Password |
Configured when you create the server database template. For more information, see Setting the Password for the Local Database Administrator. |
User ID and password on the server database |
For more information, see Parameters of the Synchronization Manager Server Component. |
Password for the DBA account |
Configured when you run the Generate New Database server component. For more information, see Parameters of the Generate New Database Server Component. |
Synchronization password |
For more information, see Configuring the Remote Client to Automatically Synchronize. |
Authentication accounts and passwords |
For more information, see Creating Accounts and Passwords. |
User name and password for the Siebel Gateway Name Server |
For more information, see Registering a New Password with the Siebel Gateway Name Server. |
Table owner password on the regional database |
For more information, see Parameters of the Regional Database Initialization Program. |
