Siebel Application Integration for Oracle Fusion Middleware Guide > Deploying Siebel Resource Adapters by Using SAI for Oracle Fusion Middleware > Process of Configuring Credential Mapping for SAI for Oracle Fusion Middleware >
Configuring Credential Mapping for SAI for Oracle Fusion Middleware on Oracle WebLogic Server
Use the following procedure to configure credential mapping for SAI for Oracle Fusion Middleware on Oracle WebLogic Server.
This task is a step in Process of Configuring Credential Mapping for SAI for Oracle Fusion Middleware.
To configure credential mapping for SAI for Oracle Fusion Middleware on Oracle WebLogic Server
  1. Log in to the Oracle WebLogic Server Administration Console.
  2. In the Deployment domain, select Deployments.
  3. Select the Siebel Resource Adapter for which you want to configure credential mapping.
  4. Click the Security tab, and then click the Credential Mappings tab.
  5. Select New to create a new mapping.
  6. Select the appropriate Outbound Connection Pool, and then click Next.
    For example, if you chose SiebelResourceAdapter above, then you might want to choose eis/siebel/SiebelResourceAdapterConnFactory.
  7. Select Default User, and then click Next.
  8. Enter the EIS user name and password to create the initial new connections, and then Click Finish.
    NOTE:  Enter the same user name and password that you specified in the Resource Adapter Descriptor parameters during the Siebel Resource Adapter deployment. For information about the Resource Adapter Descriptor parameters, see Step 7 in Configuring Siebel Server Load Balancing and SSL for SAI for Oracle Fusion Middleware.
    A message appears indicating the new security map entry for the resource adapter was successfully created.
Related Topics
About Protecting User Names and Passwords for SAI for Oracle Fusion Middleware
Process of Deploying Siebel Resource Adapters Using SAI for Oracle Fusion Middleware
Reconfiguring the Connection Pool on Oracle WebLogic Server for SAI for Oracle Fusion Middleware
Siebel Application Integration for Oracle Fusion Middleware Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
