Siebel Application Integration for Oracle Fusion Middleware Guide
What's New in This Release
Back to top
Overview of SAI for Oracle Fusion Middleware
About SAI for Oracle Fusion Middleware
How SAI for Oracle Fusion Middleware Relates to Siebel EAI
How Does SAI for Oracle Fusion Middleware Work?
About Oracle WebLogic Server
About Oracle WebLogic Server Domains
Components of an Oracle WebLogic Server Domain
About Oracle WebLogic Server Clusters
About System Administration Tools for Oracle WebLogic Server
Oracle WebLogic Server Administration Console
Oracle WebLogic Server Configuration Wizard
Oracle WebLogic Server Domain Template Builder
Oracle WebLogic Server Domain Upgrade Wizard
Oracle WebLogic Server Node Manager
About the WebLogic Scripting Tool
About Oracle JDeveloper
About the SAI for Oracle Fusion Middleware Wizards
Back to top
Installing, Configuring, and Upgrading SAI for Oracle Fusion Middleware
About the SAI for Oracle Fusion Middleware Extension Bundle
Roadmap for Installing and Configuring SAI for Oracle Fusion Middleware
Requirements for Using SAI for Oracle Fusion Middleware with Siebel Business Applications
Applying the Latest Repository, Schema, and Seed Data Changes
Installing SAI for Oracle Fusion Middleware
Setting Preferences for SAI for Oracle Fusion Middleware
Modifying Database Parameters for Use with SAI for Oracle Fusion Middleware
Process of Configuring SAI for Oracle Fusion Middleware for Outbound Web Services
Configuring the Siebel Server to Use SAI for Oracle Fusion Middleware for Outbound Web Services
Configuring Oracle WebLogic Server for Outbound Web Services Using SAI for Oracle Fusion Middleware
Configuring Oracle JDeveloper for Outbound Web Services Using SAI for Oracle Fusion Middleware
Manually Installing Jersey Libraries for SAI for Oracle Fusion Middleware
Logging In to the Oracle WebLogic Server Administration Console
About Upgrading SAI for Oracle Fusion Middleware
Back to top
Setting Up Security for SAI for Oracle Fusion Middleware on Oracle WebLogic Server
About Oracle WebLogic Server Security Realms
About the Security Models for SAI for Oracle Fusion Middleware
Setting Up Security on Oracle WebLogic Server for SAI for Oracle Fusion Middleware
Back to top
Deploying Siebel Resource Adapters by Using SAI for Oracle Fusion Middleware
About Resource Adapters
Process of Deploying Siebel Resource Adapters Using SAI for Oracle Fusion Middleware
About Protecting User Names and Passwords for SAI for Oracle Fusion Middleware
Process of Configuring Credential Mapping for SAI for Oracle Fusion Middleware
Configuring Credential Mapping for SAI for Oracle Fusion Middleware on Oracle WebLogic Server
Reconfiguring the Connection Pool on Oracle WebLogic Server for SAI for Oracle Fusion Middleware
Configuring Siebel Server Load Balancing and SSL for SAI for Oracle Fusion Middleware
About Testing Your Siebel Resource Adapter Deployment
Back to top
Working with Web Services Using SAI for Oracle Fusion Middleware
About Oracle WebLogic Web Services
Compliance Standards for SAI for Oracle Fusion Middleware Web Services
About Working with Web Services Using SAI for Oracle Fusion Middleware
About Base Integration Objects
About Binding Options and Settings for Controlling the Structure of SOAP Messages
About Using the JMS Connector with SAI for Oracle Fusion Middleware
Process of Deploying Inbound Web Services Using SAI for Oracle Fusion Middleware
Creating Inbound Web Services Based on Siebel Business Services
Creating Inbound Web Services Based on Siebel Workflow Processes
Deploying Siebel Inbound Web Services Using SAI for Oracle Fusion Middleware
Deploying Enterprise Java Beans Using SAI for Oracle Fusion Middleware
Accessing WSDLs for Deployed Inbound Web Services in the Oracle WebLogic Server Administration Console
Roadmap for Deploying Outbound Web Services Using SAI for Oracle Fusion Middleware
Referencing Oracle WebLogic Server Outbound Web Services in Siebel Business Applications
Configuring JMS Resource Adapters for Outbound Web Services Using SAI for Oracle Fusion Middleware
Testing Outbound Web Services Using SAI for Oracle Fusion Middleware
Back to top
Working with Siebel RESTful Services
Overview of Siebel RESTful Services
Architecture of Siebel RESTful Services
How Siebel RESTful Services Map HTTP to the EAI Object Manager
HTTP URI Pattern for Siebel RESTful Services
About URI Parameters
Deploying Siebel RESTful Services Using SAI for Oracle Fusion Middleware
Architecture of Siebel RESTful Services Messages
Sample URIs for Siebel RESTful Services
Example of Using Code to Access Data from the Siebel File System
Example of Using Code to Insert Data into the Siebel File System
Back to top
Working with XSDs Using SAI for Oracle Fusion Middleware
About Working with XSDs Using SAI for Oracle Fusion Middleware
Process of Designing and Deploying XSDs Using SAI for Oracle Fusion Middleware
Designing XSDs Using SAI for Oracle Fusion Middleware
About Using XSDs with Siebel RESTful Services
Undeploying XSDs That Were Created Using SAI for Oracle Fusion Middleware
Back to top
Migrating Siebel Web Services to Oracle WebLogic Server
Benefits of Migrating Siebel Web Services to Oracle WebLogic Server
Process of Migrating SOAP Services Using SAI for Oracle Fusion Middleware
Migrating Existing Siebel Inbound Web Services to Oracle WebLogic Server
Migrating Existing Siebel Outbound Web Services to Oracle WebLogic Server
Example of Testing Migrated Outbound Web Services by Using SAI for Oracle Fusion Middleware
Back to top
Troubleshooting SAI for Oracle Fusion Middleware
Enabling and Examining Troubleshooting Information on the Oracle WebLogic Server
Setting Log Levels for SAI for Oracle Fusion Middleware
Troubleshooting Errors for SAI for Oracle Fusion Middleware
Back to top
Glossary
Back to top
Siebel Application Integration for Oracle Fusion Middleware Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
