Siebel Application Integration for Oracle Fusion Middleware Guide > Overview of SAI for Oracle Fusion Middleware > About Oracle WebLogic Server DomainsBefore you can develop and run a WebLogic application, you must first create a domain. A domain is an interrelated set of Oracle WebLogic Server resources that is managed as a unit. For information about creating domains, see Oracle WebLogic Server Configuration Wizard. A domain includes one or more Oracle WebLogic Server instances, which can form clusters, instances, or a combination of both. A domain can include multiple clusters. For more information about clusters, see About Oracle WebLogic Server Clusters. A domain also contains the application components deployed in the domain and the resources and services required by those application components and the server instances in the domain. Examples of the resources and services used by applications and server instances include computer definitions, optional network channels, connectors, and startup classes. After you create a domain, you can start an Oracle WebLogic Server instance to run in the domain for developing, testing, and deploying applications. As shown in Figure 2, an Oracle WebLogic domain consists of the following: An Oracle WebLogic domain is managed using the Oracle WebLogic Server System Administration Tools. For more information about these tools, see About System Administration Tools for Oracle WebLogic Server. Figure 2 illustrates the structure of an Oracle WebLogic domain: |
| Siebel Application Integration for Oracle Fusion Middleware Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
