Siebel Application Integration for Oracle Fusion Middleware Guide > Overview of SAI for Oracle Fusion Middleware > About System Administration Tools for Oracle WebLogic Server > Oracle WebLogic Server Configuration WizardThis topic provides a high-level description of the Oracle WebLogic Server Configuration Wizard and how to use it. For more information about this wizard, see Oracle® Fusion Middleware Creating Domains Using the Configuration Wizard 11g Release 1 (10.3.1) in the Oracle Fusion Middleware 11g Release 1 Documentation Library. You use the Configuration Wizard to create and extend domains. For more information about domains, see About Oracle WebLogic Server Domains. You create and extend domains using the Configuration Wizard by selecting the product components you want included in the domain (or choose a template that best meets your requirements), and provide basic configuration information. The Configuration Wizard then creates or extends the domain by using the settings from the templates. Before you can develop and run an Oracle WebLogic application, you must first create a domain. After you create a domain, you can start an Oracle WebLogic Server instance to run in the domain for developing, testing, and deploying applications. |
| Siebel Application Integration for Oracle Fusion Middleware Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
