Aaccessing data from the Siebel File System, example of 1 Administration Console about 1 accessing WSDLs for deployed inbound Web services 1 logging in to 1 what you use it for 1 administration server, about 1 Bbase integration object, described 1 Cclusters about 1 described 1 Configuration Wizard, about 1 configuring Oracle JDeveloper for outbound Web services by using SAI for Oracle Fusion Middleware 1 configuring Oracle WebLogic Server for outbound Web services using SAI for Oracle Fusion Middleware 1 configuring SAI for Oracle Fusion Middleware for outbound Web services, process of 1 configuring the Siebel Server for SAI for Oracle Fusion Middleware for outbound Web services 1 Ddeploying inbound Web services using SAI for Oracle Fusion Middleware, process of 1 outbound Web services using SAI for Oracle Fusion Middleware, roadmap for 1 Siebel Resources Adapters, process of Siebel RESTful Services using SAI for Oracle Fusion Middleware 1 XSDs using SAI for Oracle Fusion Middleware 1 XSDs using SAI for Oracle Fusion Middleware, process of 1 designing XSDs using SAI for Oracle Fusion Middleware 1 XSDs using SAI for Oracle Fusion Middleware, process of 1 Domain Template Builder, about 1 Domain Upgrade Wizard about 1 graphical mode, when to use 1 silent mode, when to use 1 upgrade modes for 1 domains about 1 components of 1 configuration of 1 EEAI Object Manager how Siebel RESTful Services map HTTP to it 1 Enterprise Java Beans, deploying using SAI for Oracle Fusion Middleware 1 extension bundle, about 1 HHTTP resource request DELETE 1 GET 1 POST 1 PUT 1 Iinbound Web services accessing WSDLs in the Administration Console 1 creating for SAI for Oracle Fusion Middleware based on Siebel business services 1 creating for SAI for Oracle Fusion Middleware based on Siebel workflow processes 1 deploying using SAI for Oracle Fusion Middleware 1 deploying using SAI for Oracle Fusion Middleware, process of 1 migrating from Siebel application to Oracle WebLogic Server 1 inserting data in to the Siebel File System, example of 1 installing and configuring SAI for Oracle Fusion Middleware roadmap for 1 roadmap for, diagram of 1 installing Jersey libraries for SAI for Oracle Fusion Middleware 1 Lload balancing configuring the Siebel Server for SAI for Oracle Fusion Middleware 1 Mmanaged servers, about 1 migrating Siebel Web services to Oracle WebLogic Server, benefits of 1 migrating SOAP services using SAI for Oracle Fusion Middleware, process of 1 NNode Manager about 1 Java-based, described 1 script-based, described 1 OOracle JDeveloper, about 1 Oracle WebLogic domain structure, diagram of 1 Oracle WebLogic Server about 1 connection pool, reconfiguring for SAI for Oracle Fusion Middleware 1 enabling and examining troubleshooting 1 migrating existing Siebel inbound Web services to 1 migrating existing Siebel outbound Web services to 1 migrating Siebel Web services to, benefits of 1 referencing outbound Web services in Siebel Business Applications 1 security realms, about 1 setting up security for SAI for Oracle Fusion Middleware 1 system administration tools for 1 Oracle WebLogic Web services about 1 outbound Web services configuring JMS resource adapters using SAI for Oracle Fusion Middleware 1 deploying using SAI for Oracle Fusion Middleware 1 deploying using SAI for Oracle Fusion Middleware, roadmap for 1 migrating from Siebel application to Oracle WebLogic Server 1 testing migrated services using SAI for Oracle Fusion Middleware, example of 1 testing using SAI for Oracle Fusion Middleware 1 outbound Web services, referencing Oracle WebLogic Server outbound Web services in Siebel Business Applications 1 Pprotecting user names and passwords for SAI for Oracle Fusion Middleware 1 RRepresentational State Transfer (RESTful) Services, working with 1 resource adapter about 1 log files for 1 naming conventions for 1 SSAI for Oracle Fusion Middleware about 1 about working with XSDs 1 applying repository, schema, and seed data changes for 1 configuring for outbound Web services, process of 1 configuring JMS resource adapters for outbound Web services using 1 configuring Oracle JDeveloper for outbound Web services 1 configuring Oracle WebLogic Server for outbound Web services 1 configuring the Siebel Server to use for outbound Web services 1 creating inbound Web services based on Siebel business services 1 creating inbound Web services based on Siebel workflow processes 1 deploying Enterprise Java Beans using 1 deploying inbound Web services using SAI for Oracle Fusion Middleware 1 deploying outbound Web services using 1 extension bundle, about 1 how it relates to Siebel EAI 1 how it works 1 installing 1 installing and configuring, roadmap for 1 JMS connector, about using with 1 manually installing Jersey libraries for 1 migrating SOAP services using 1 modify database parameters for 1 protecting user names and passwords for 1 reconfiguring the connection pool on Oracle WebLogic Server 1 requirements for using with Siebel Business Applications 1 security models, about 1 security realms, about 1 setting log levels for 1 setting preferences for 1 testing migrated outbound Web services, example of 1 testing outbound Web services using 1 troubleshooting errors for 1 upgrading, about 1 Web services, working with 1 wizards, about 1 workflow for 1 workflow, diagram of 1 Secure Sockets Layer, configuring the Siebel Server for SAI for Oracle Fusion Middleware 1 security models for SAI for Oracle Fusion Middleware 1 realms for the Oracle WebLogic Server 1 setting up on Oracle WebLogic Server for SAI for Oracle Fusion Middleware 1 security models Custom Roles and Policies models, described 1 Deployment Descriptor Only model, described 1 Siebel Resource Adapter deploying using SAI for Oracle Fusion Middleware, process of 1 testing your deployment 1 Siebel RESTful Services architecture 1 architecture, diagram of 1 deploying 1 how it maps HTTP to the EAI Object Manager 1 HTTP URI pattern for 1 overview 1 sample URIs 1 using XSDs with 1 Siebel RESTful Services messages architecture of 1 message body, structure of 1 message header, request example 1 SOAP services migrating using SAI for Oracle Fusion Middleware, process of 1 standards for Oracle Fusion Middleware Web services 1 Ttroubleshooting enabling on the Oracle WebLogic Server 1 setting log levels for SAI for Oracle Fusion Middleware 1 solutions for SAI for Oracle Fusion Middleware errors 1 Uundeploying XSDs using SAI for Oracle Fusion Middleware 1 update mode parameter insert, described 1 mixed, described 1 sync, described 1 update, described 1 upsert, described 1 upgrading SAI for Oracle Fusion Middleware, about 1 URI HTTP request determine if REST server is up 1 fetch schema of a repository object 1 invoke delete operation 1 invoke insert operation 1 invoke query operations 1 invoke upsert operation 1 retrieve attachments 1 sample XML for uploading attachments 1 URI parameter about 1 pagesize 1 searchexpr 1 sortexpr 1 startrow 1 syntax for 1 updatemode 1 viewmode 1 WWeb services about Oracle WebLogic services 1 compliance standards for SAI for Oracle Fusion Middleware Web services 1 using SAI for Oracle Fusion Middleware 1 WebLogic Scripting Tool about 1 embedded mode, described 1 script mode, described 1 wizards, about 1 XXSDs deploying using SAI for Oracle Fusion Middleware 1 designing and deploying using SAI for Oracle Fusion Middleware, process of 1 designing using SAI for Oracle Fusion Middleware 1 undeploying using SAI for Oracle Fusion Middleware 1 using with Siebel RESTful Services 1 working with using SAI for Oracle Fusion Middleware 1 |
| Siebel Application Integration for Oracle Fusion Middleware Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
