 Siebel Application Integration for Oracle Fusion Middleware Guide > Working with XSDs Using SAI for Oracle Fusion Middleware >
Process of Designing and Deploying XSDs Using SAI for Oracle Fusion Middleware
You use Oracle JDeveloper to design and deploy XML Schema Definitions (XSDs) using SAI for Oracle Fusion Middleware to support various Web service deployments. You can create XSDs for immediate use or save them for future deployment. To design and deploy XSDs using SAI for Oracle Fusion Middleware, perform the following tasks:
- Designing XSDs Using SAI for Oracle Fusion Middleware
 - Deploying XSDs Using SAI for Oracle Fusion Middleware
Related Topics
About Working with XSDs Using SAI for Oracle Fusion Middleware
About Using XSDs with Siebel RESTful Services
Undeploying XSDs That Were Created Using SAI for Oracle Fusion Middleware
