Siebel Application Integration for Oracle Fusion Middleware Guide > Working with XSDs Using SAI for Oracle Fusion Middleware > About Using XSDs with Siebel RESTful ServicesAfter you deploy your XSD files to Oracle WebLogic Server, you can use these files for CRUD operations, similar to other integration objects used for REST calls. The following is a sample URI pattern: http://weblogic_server_IP:port/oracle-crm/api/rest/siebel/JNDI_ra_name/deployed_xsd_name?searchexpr=[IntCompName.IntCompFieldName] search_expression The following is a sample URI example: http://localhost:7101/oracle-crm/api/rest/siebel/siebel.SiebelResourceAdapterConnFactory/Base%20Account_0_0.xsd?searchexpr=[Account.Name]like"A*" Related Topics |
| Siebel Application Integration for Oracle Fusion Middleware Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
