Siebel Application Integration for Oracle Fusion Middleware Guide > Working with XSDs Using SAI for Oracle Fusion Middleware > Process of Designing and Deploying XSDs Using SAI for Oracle Fusion Middleware >
This topic describes how to deploy XSDs using SAI for Oracle Fusion Middleware.
This task is a step in Process of Designing and Deploying XSDs Using SAI for Oracle Fusion Middleware.
To deploy XSDs using SAI for Oracle Fusion Middleware
  1. Make sure you have deployed an appropriate Siebel Resource Adapter.
    For information about deploying Siebel Resource Adapters, see Process of Deploying Siebel Resource Adapters Using SAI for Oracle Fusion Middleware.
  2. Start Oracle JDeveloper.
  3. From the application-level menu, select File, and then click the New menu item.
  4. In the New Gallery dialog box, perform the following:
    1. In the Business Tier category, select Siebel Application Integration for Oracle Fusion Middleware.
    2. Select the Deployment item, and then click OK.
  5. At the Welcome to the Deployment wizard screen, click Next.
  6. Select XSD, and then click Next.
  7. Select Deploy XSDs, and then click Next.
  8. Select the XSD files you want to deploy by moving them from the Available section to the Selected section.
    NOTE:  The path is the XSD File Path parameter specified in the SAI for Oracle Fusion Middleware Preferences. For more information, see Setting Preferences for SAI for Oracle Fusion Middleware.
  9. (Optional) If you want to preview an XSD file that will be deployed, then select the XSD file in the Selected section, click View XSD, and then click Close to return to the Choose XSDs wizard page.
  10. Enter the deployed Siebel Resource Adapter information by doing the following:
    1. Enter details of the resource adapter you are using for the deployment.
    2. Enter the resource adapter connection factory JNDI name.
    3. Click Next.
      NOTE:  These settings are specified in the Deployment tab in the SAI for Oracle Fusion Middleware Preferences. For more information, see Setting Preferences for SAI for Oracle Fusion Middleware.
  11. Enter the Oracle WebLogic Server parameters, and then click Next.
    For a description of the parameters, see Siebel Application Integration for Oracle Fusion Middleware: Oracle JDeveloper Online Help.
  12. Review the summary, and then click Finish.
    The XSD file is deployed to Oracle WebLogic Server.
Related Topics
About Working with XSDs Using SAI for Oracle Fusion Middleware
Designing XSDs Using SAI for Oracle Fusion Middleware
About Using XSDs with Siebel RESTful Services
Undeploying XSDs That Were Created Using SAI for Oracle Fusion Middleware
Siebel Application Integration for Oracle Fusion Middleware Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
