Siebel Application Integration for Oracle Fusion Middleware Guide > Working with XSDs Using SAI for Oracle Fusion Middleware >
Undeploying XSDs That Were Created Using SAI for Oracle Fusion Middleware
This topic describes how to undeploy XSDs that were created using SAI for Oracle Fusion Middleware.
This task is a step in Process of Designing and Deploying XSDs Using SAI for Oracle Fusion Middleware.
  1. Make sure you have deployed an appropriate Siebel Resource Adapter.
    For information about deploying Siebel Resource Adapters, see Process of Deploying Siebel Resource Adapters Using SAI for Oracle Fusion Middleware.
  2. Start Oracle JDeveloper.
  3. From the application-level menu, select File, and then click the New menu item.
  4. In the New Gallery dialog box, perform the following:
    1. In the Business Tier category, select Siebel Application Integration for Oracle Fusion Middleware.
    2. Select the Deployment item, and then click OK.
  5. At the Welcome to the Deployment wizard screen, click Next.
  6. Select XSD, and then click Next.
  7. Select Undeploy XSDs, and then click Next.
  8. Enter the deployed Siebel Resource Adapter information by doing the following:
    1. Enter details of the resource adapter you are using for the deployment.
    2. Enter the resource adapter connection factory JNDI name.
    3. Click Next.
      NOTE:  These settings are specified in the Deployment tab in the SAI for Oracle Fusion Middleware Preferences. For more information, see Setting Preferences for SAI for Oracle Fusion Middleware.
  9. Enter the Oracle WebLogic Server parameters, and then click Next.
    For a description of the parameters, see Siebel Application Integration for Oracle Fusion Middleware: Oracle JDeveloper Online Help. Use the arrows to move the deployed XSD files from the Available section to the Selected section, and then click Next.
  10. Review the summary, and then click Finish.
    The selected XSD files will be undeployed from Oracle WebLogic Server.
Related Topics
About Working with XSDs Using SAI for Oracle Fusion Middleware
About Using XSDs with Siebel RESTful Services
Siebel Application Integration for Oracle Fusion Middleware Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
