Siebel Application Integration for Oracle Fusion Middleware Guide > Working with Web Services Using SAI for Oracle Fusion Middleware > About Working with Web Services Using SAI for Oracle Fusion MiddlewareSiebel Application Integration for Oracle Fusion Middleware (SAI for Oracle Fusion Middleware) allows you to separate service-oriented architecture (SOA) integration development completely from your Siebel Business Applications implementation. You can build Java classes or Enterprise Java Beans, expose them as Web services, automatically deploy them to an instance of Oracle WebLogic Server, and immediately test the running Web service. Alternatively, you can use Oracle JDeveloper to drive the creation of Web services from WSDL descriptions. Because Oracle JDeveloper also is Ant-aware, you can use this tool to build and run Ant scripts for assembling the client and for assembling and deploying the service. |
Siebel Application Integration for Oracle Fusion Middleware Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
