Siebel Application Integration for Oracle Fusion Middleware Guide > Troubleshooting SAI for Oracle Fusion Middleware >
Setting Log Levels for SAI for Oracle Fusion Middleware
This topic describes the various log levels for troubleshooting SAI for Oracle Fusion Middleware and how to set them. NOTE: Typically, you set the log level as part of the process of deploying SAI for Oracle Fusion Middleware. However, you can reset the level at any time.
To set log levels for SAI for Oracle Fusion Middleware
- Start Oracle JDeveloper.
- From the application-level menu, select Tools, and then the Preferences menu item.
- From the explorer, scroll down to select Siebel Application Integration for Oracle Fusion Middleware.
- Under Deployment tab, set the log level specific to your deployment.
The log levels are described in the following table.
FATAL |
This level logs severe errors that cause termination of an application. |
ERROR |
This level logs run-time errors or unexpected conditions, however, only the specified error in the log file is logged. |
WARN |
This level indicates a potential problem, such as errors in run-time situations that are undesirable or unexpected, but not necessarily causing run-time termination. |
INFO |
This level provides information on run-time events, such as startup and shutdown. |
DETAIL |
This level logs run-time errors or unexpected conditions. This level provides the most information. |
DEBUG |
This level logs detailed information on the flow through the data management system (the Siebel application server and the Oracle WebLogic Server) and prints the stack trace. |
