Siebel Application Integration for Oracle Fusion Middleware Guide > Overview of SAI for Oracle Fusion Middleware > About System Administration Tools for Oracle WebLogic Server > Oracle WebLogic Server Domain Upgrade WizardThis topic provides a high-level description of the Oracle WebLogic Server Domain Upgrade Wizard and how to use it. For more information about this wizard, see Oracle® Fusion Middleware Upgrade Guide for Oracle WebLogic Server 11g Release 1 (10.3.1) in the Oracle Fusion Middleware 11g Release 1 Documentation Library. You use the Domain Upgrade Wizard to streamline the upgrade of domains with a newer version of Oracle WebLogic Server. For example, you might want to use this wizard to upgrade a domain to version 11g that was created in version 10.3.x. You must upgrade the domains on every computer in the domain. The wizard supports the following upgrade modes:
Tasks Performed by the Upgrade WizardDuring an Oracle WebLogic domain upgrade, you specify the domain that you want to upgrade and respond to a set of prompts. The wizard performs the following tasks:
| Siebel Application Integration for Oracle Fusion Middleware Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
