Siebel Application Integration for Oracle Fusion Middleware Guide > Overview of SAI for Oracle Fusion Middleware > About System Administration Tools for Oracle WebLogic Server > Oracle WebLogic Server Node ManagerThis topic provides a high-level description of Oracle WebLogic Server Node Manager. For more information about Node Manager, see Oracle® Fusion Middleware Node Manager Administrator's Guide for Oracle WebLogic Server 11g Release 1 (10.3.1) in the Oracle Fusion Middleware 11g Release 1 Documentation Library. Node Manager is an optional Oracle WebLogic Server utility that allows you to manage server instances from a remote location. Using Node Manager, you can do the following:
NOTE: It is recommended that you use Node Manager if your Oracle WebLogic Server environment hosts applications with high-availability requirements. A node manager process is not associated with a specific Oracle WebLogic domain but with a computer. You can use the same Node Manager process to control server instances in any Oracle WebLogic Server domain, as long as the server instances reside on the same computer as the node manager process. Node Manager must run on each computer that hosts Oracle WebLogic Server instances that you want to control with Node Manager. Oracle WebLogic Server supports the following two versions of Node Manager:
NOTE: Java-based Node Manager provides more security than the script-based version. However, the advantage of the script-based Node Manager is that it can remotely manage servers over a network that has been configured to use SSH. No additional server installation is required. You copy the scripts to the remote computer. |
| Siebel Application Integration for Oracle Fusion Middleware Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
