Siebel Application Integration for Oracle Fusion Middleware Guide > Overview of SAI for Oracle Fusion Middleware > About System Administration Tools for Oracle WebLogic Server > About the WebLogic Scripting ToolThis topic provides a high-level description of the WebLogic Scripting Tool. For more information about this tool, see Oracle® Fusion Middleware Oracle WebLogic Scripting Tool 11g Release 1 (10.3.1) in the Oracle Fusion Middleware 11g Release 1 Documentation Library. WebLogic Scripting Tool is a command-line scripting environment that you can use to create, manage, and monitor Oracle WebLogic Server instances and domains as well as monitor and manage server run-time events. WebLogic Scripting Tool is based on the Java scripting interpreter, Jython. You can use WebLogic Scripting Tool as the command-line equivalent to the Oracle WebLogic Server Administration Console (online) or as the command-line equivalent to the Configuration Wizard (offline). You can use any of the following modes to call WebLogic Scripting Tool commands:
| Siebel Application Integration for Oracle Fusion Middleware Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
