Siebel Application Integration for Oracle Fusion Middleware Guide > Migrating Siebel Web Services to Oracle WebLogic Server > Process of Migrating SOAP Services Using SAI for Oracle Fusion Middleware >
Migrating Existing Siebel Inbound Web Services to Oracle WebLogic Server
This topic describes how to migrate existing Siebel inbound Web services to Oracle WebLogic Server. This task is a step in Process of Migrating SOAP Services Using SAI for Oracle Fusion Middleware. To migrate existing Siebel inbound Web services to Oracle WebLogic Server
- Launch Oracle JDeveloper, if not already active.
- Select File, and then click the New menu item.
- In the New Gallery dialog box, perform the following:
- In the Business Tier category, select Siebel Application Integration for Oracle Fusion Middleware.
- Select the Migration item, and then click OK.
- At the Welcome to the Migration Wizard screen, click Next.
- Select the service or services you want to migrate by checking the relevant check boxes from the list of Siebel Inbound Web Services. Check the Auto-deploy to Oracle WebLogic Server option if you want to directly deploy the migrated services, and then click Next.
NOTE: The list populates automatically with the inbound Web services that are noted as active in the Administration - Web Services screen, Inbound Web Services view in the Siebel application.
- If you selected the Auto-deploy to Oracle WebLogic Server option, then enter the inbound deployment parameters, and then click Next. Otherwise, skip to Step 8.
For information about these parameters, see Step 8 in Deploying Enterprise Java Beans Using SAI for Oracle Fusion Middleware.
- Enter the Oracle WebLogic Server parameters, and then click Next.
For information about these parameters, see Step 7 in Process of Deploying Siebel Resource Adapters Using SAI for Oracle Fusion Middleware.
- Click Finish to start the migration.
The code required to expose existing inbound Web services generates and is available for deployment to Oracle WebLogic Server at a later time. If the autodeploy option is selected, then the Web service will be deployed to Oracle WebLogic Server.
NOTE: If code was previously generated for this service, then a warning appears asking if you want to overwrite it. If you click Yes, then the folder structure is overwritten. If you click No, then a dialog box appears in which you can name a new folder structure and save that structure in a directory of your choice.
