Siebel Application Integration for Oracle Fusion Middleware Guide > Migrating Siebel Web Services to Oracle WebLogic Server > Process of Migrating SOAP Services Using SAI for Oracle Fusion MiddlewareThere are two phases in working with SOAP (Simple Object Access Protocol) services using SAI for Oracle Fusion Middleware. The first phase is the code generation phase where you use Oracle JDeveloper to create Java artifacts that represent one or more SOAP services. These services may relate to a migration of an existing Siebel EAI Web service or a completely new service implementation. The second phase takes the output of the first phase (the generated code), and deploys it to Oracle WebLogic Server. NOTE: SAI for Oracle Fusion Middleware supports migration of single-port Siebel Web services. Multiple-port migration is not supported. To migrate SOAP services using SAI for Oracle Fusion Middleware, perform the following tasks: |
| Siebel Application Integration for Oracle Fusion Middleware Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
