Siebel Application Integration for Oracle Fusion Middleware Guide > Overview of SAI for Oracle Fusion Middleware > About SAI for Oracle Fusion MiddlewareSAI for Oracle Fusion Middleware is an enterprise application integration infrastructure that allows you to create composite applications with a single view of data in the entire enterprise. A composite application is an application built by combining multiple existing functions into a new application drawn from several different sources. The components can be individual selected functions from within other applications, or entire data management systems whose outputs have been packaged as business functions, modules, or Web services. Using SAI for Oracle Fusion Middleware, you can resolve inherent integration challenges because you can do the following:
SAI for Oracle Fusion Middleware is built on Oracle's standards-compliant middleware. Session management and user impersonation provide a more linear progression when scaling for modern integration patterns, and you use new migration tools to move existing Siebel Enterprise Application Integration (EAI) Web services to the new architecture. And, because there is no dependence on Siebel integration resources, there is enhanced performance for SOA development. Some of the benefits of using SAI for Oracle Fusion Middleware include:
| Siebel Application Integration for Oracle Fusion Middleware Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
