Siebel Application Integration for Oracle Fusion Middleware Guide > Working with Siebel RESTful Services >
Sample URIs for Siebel RESTful Services
Table 8 provides sample Uniform Resource Identifiers (URIs) that you can use for working with Siebel RESTful Services.
Table 8. Sample URIs
Task
HTTP
Request
Type
Sample URI
Determine REST server is up
GET
http://weblogic_server_IP:port/oracle-crm/api/rest/siebel/heartbeat
The response you want is: The REST server is alive.
To invoke query operations
GET
To query by row ID:
http://weblogic_server_IP:port/oracle-crm/api/rest/siebel/JNDI_ra_name/IO_name/ID
The response is XML output for all of the fields that are defined and active in the integration component for that particular record.
NOTE:  The query by row ID HTTP request is the same as that used for the delete operation, however, the HTTP request type for the delete operation is DELETE, not GET.
POST
To query by example:
http://weblogic_server_IP:port/oracle-crm/api/rest/siebel/JNDI_ra_name/IO_name/query
Sample request XML:
<?xml version = '1.0' encoding = 'utf-8'?>
<SiebelREST>
<ListOfAccount_EMR>
<Account>
<Name>A*</Name>
</Account>
</ListOfAccount_EMR>
</SiebelREST>
NOTE:  All requests with POST HTTP request type are either insert or upsert operations.
To invoke query operations (CONTINUED)
GET
To query by search spec:
http://weblogic_server_IP:port/oracle-crm/api/rest/siebel/JNDI_ra_name/IO_name?searchexpr=[IntCompName.IntCompFieldName] LIKE 'A*'
To invoke delete operation
DELETE
To delete by row ID:
http://weblogic_server_IP:port/oracle-crm/api/rest/siebel/JNDI_ra_name/IO_name/<ID>
Sample response XML:
<SiebelREST>
<ErrorCode>0x0</ErrorCode>
<ListOfAccountAttOrderAtt>
<Account/>
</ListOfAccountAttOrderAtt>
</SiebelREST>
TIP:   ErrorCode 0x0 indicates that the deletion operation was successful.
NOTE:  The delete HTTP request is the same as that used for the query by row ID operation, however, the HTTP request type for the query by row ID operation is GET, not DELETE. Additionally, the XML returned by the DELETE operation is similar to that of an update-insert-upsert operation.
To invoke insert operation
POST
http://weblogic_server_IP:port/oracle-crm/api/rest/siebel/JNDI_ra_name/IO_name?updatemode=insert
Sample request XML:
<?xml version="1.0" encoding="ISO-8859-1"?>
<SiebelREST>
<Account>
<Name>AttachAbhishek36</Name>
<Location>HeadQuarter</Location>
<Currency_0x20_Code>BRL</Currency_0x20_Code>
<Primary_0x20_Organization>Default Organization</Primary_0x20_Organization>
</Account>
</SiebelREST>
After performing this insert operation, the resultant XML specifies the new row ID that was created as a result of the insert operation.
<SiebelREST> <ErrorCode>0x0</ErrorCode>
<PrimaryRowId>42-JIMUV</PrimaryRowId>
<Account> <Name>AttachAbhishek36</Name>
</Account> </ListOfAccountAttOrderAtt>
</SiebelREST>
To invoke upsert operation
POST
http://weblogic_server_IP:port/oracle-crm/api/rest/siebel/JNDI_ra_name/IO_name?updatemode=upsert
Sample request XML:
<SiebelREST>
<Account>
<Name>InsertAccount1</Name>
<Currency_0x20_Code>USD</Currency_0x20_Code>
</Account>
</SiebelREST>
To fetch schema of a repository object
GET
http://weblogic_server_IP:port/oracle-crm/api/rest/siebel/JNDI_ra_name/IO_name/schema
To retrieve attachments
POST
Make sure that the integration object has an attachment integration component using the following code structure:
NOTE:  The following code is part of a larger message. For the complete message structure, see Sample XML for Uploading Attachments.
<Attachments>
<Document>
<Attachment_0x20_Data>QXR0YWNobWVudHMgZm9yIFJFU1QgQVBJLg==</Attachment_0x20_Data>
<TimedOut>false</TimedOut>
<AttachmentIsTextData>false</AttachmentIsTextData>
<ContentId>1234</ContentId>
<Extension>txt</Extension>
</Document>
</Attachments>
NOTE:  When the value is set to true (<AttachmentIsTextData>false</AttachmentIsTextData>), the attachment data is not decoded. The created attachment on the Siebel Server side is the same as that provided in the <Attachment_0x20_Data> tag.
The following provides sample XML for uploading attachments. For a sample URI, see the POST call for retrieving attachments in Table 8.
<SiebelREST>
<Account>
<Name>Insert_Account2</Name>
<ListOfAccount_0x20_Attachment>
<Account_0x20_Attachment>
<AccntFileSrcType>FILE</AccntFileSrcType>
<AccntFileName>att</AccntFileName>
<AccntFileExt>txt</AccntFileExt>
<Accnt_0x20_Attachment_0x20_Id>1234</Accnt_0x20_Attachment_0x20_Id>
</Account_0x20_Attachment>
</ListOfAccount_0x20_Attachment>
</Account>
<Attachments>
<Document>
<EndOfData>true</EndOfData>
</Document>
</Attachments>
</SiebelREST>
Siebel Application Integration for Oracle Fusion Middleware Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
