Siebel Application Integration for Oracle Fusion Middleware Guide > Deploying Siebel Resource Adapters by Using SAI for Oracle Fusion Middleware > About Testing Your Siebel Resource Adapter DeploymentAfter you have deployed SAI for Oracle Fusion Middleware and applied the security configurations, test your deployment. If you have Siebel RESTful Services deployed, then you might want to test that deployment. For information about Siebel RESTful Services, see Working with Siebel RESTful Services. If you have not deployed Siebel RESTful Services, then try deploying another service type, and check its connectivity by using the Oracle WebLogic Server tools or an external Web service client. |
Siebel Application Integration for Oracle Fusion Middleware Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
