Siebel Application Integration for Oracle Fusion Middleware Guide > Working with Web Services Using SAI for Oracle Fusion Middleware >
Deploying Outbound Web Services Using SAI for Oracle Fusion Middleware
This topic describes how to deploy outbound Web services using SAI for Oracle Fusion Middleware. This task is a step in Roadmap for Deploying Outbound Web Services Using SAI for Oracle Fusion Middleware. To deploy an outbound Web service using SAI for Oracle Fusion Middleware
- Start Oracle JDeveloper.
- From the application-level menu, select File, and then click the New menu item.
- In the New Gallery dialog box, perform the following:
- In the Business Tier category, select Siebel Application Integration for Oracle Fusion Middleware.
- Select the Deployment item, and then click OK.
- In the Welcome to the Deployment Wizard screen, click Next.
- Select Siebel Outbound Services for the type of deployment, and then click Next.
- Enter or browse for the WSDL (Web Services Description Language) file or enter the URI (Uniform Resource Identifier) for the WSDL, and then click Next.
NOTE: The other fields in this screen automatically populate.
- Enter the Oracle WebLogic Server parameters, and then click Next.
For information about the Oracle WebLogic Server parameters, see Process of Deploying Siebel Resource Adapters Using SAI for Oracle Fusion Middleware.
- Verify the summary and read the applicable notes, and then click Finish to deploy the outbound Web service.
- (Optional) If code was previously created for this service, then a dialog box appears asking you to confirm overwriting the existing code. Click Yes to continue, if appropriate.
