Siebel CTI Administration Guide > Configuring Advanced Communications Features > Integrating with Siebel Scripting Languages >
Integrating Scripting Using Server Scripts
Here are some examples of using business services and Siebel scripting with your communications configurations. These examples are for server-side scripting using Siebel eScript.
Event Response Example
Table 43 shows an example event response that invokes the server-layer scripting business service method CTI_Test.EvtBSGotoView. This event response retrieves work item data and generates a screen pop to the view Contact List View, with all contacts whose last name starts with the letter S.
Table 43. Event Response: OnInboundCallReceived
Parameter Name
Parameter Value
ServiceMethod
ServiceParam.myWorkItemID
{SiebelWorkItemID}
ServiceParam.ANI
{ANI}
Command Example
Table 44 and Table 45 show an example communications command and associated command data that invokes the server-layer scripting business service method CTI_Test.CmdBSGotoView. This command makes an outbound phone call to the number the user specified in the communications toolbar's text input field.
Table 44. Command: MakeCallToPhone
Parameter Name
Parameter Value
ServiceMethod
CmdData
MakeCallToPhone
OnEditControl
True
Table 45 shows a command data definition for this command definition.
Table 45. Command Data: MakeCallToPhone
Parameter Name
Parameter Value
ServiceParam.PhoneNumber
{@Phone:PhoneTypeLookup}
RequiredField.@Phone
Param.CallNotifyText
Call from {@UserName}...
Server Script Examples
Define the following server scripts in the CTI_Test business service. These scripts are invoked by the event response and command described in Event Response Example and Command Example:
function Service_PreCanInvokeMethod (MethodName, &CanInvoke)
   var ReturnVal = ContinueOperation;
   switch (MethodName)
      case "EvtBSGotoView":
      case "CmdBSGotoView":
      CanInvoke = "True";
      ReturnVal = CancelOperation;
   return (ReturnVal);
function Service_PreInvokeMethod (MethodName, Inputs, Outputs)
   switch (MethodName)
         EvtBSGotoView(Inputs, Outputs);
         break;
          CmdBSGotoView(Inputs, Outputs);
          break;
   return (ReturnVal);
function EvtBSGotoView(Inputs, Outputs)
   // Getting input arguments from Event Response parameters
   var itemID = Inputs.GetProperty("myWorkItemID");
   var ANI = Inputs.GetProperty("ANI");
   // Invoking Business Service "Communications Session Manager" method
   var ctibs = TheApplication().GetService("Communications Session Manager");
   var ip = TheApplication().NewPropertySet();
   var op = TheApplication().NewPropertySet();
   ip.SetProperty("WorkItemID", itemID);
   ctibs.InvokeMethod("GetWorkItemInfo", ip, op);
   // Generate a screen pop to "Contact List View" with
   // all the contacts whose last name start with letter "S"
   var boGlobal = TheApplication().GetBusObject("Contact");
   var bcContact = boGlobal.GetBusComp("Contact");
   bcContact.SetViewMode(AllView);
   bcContact.ClearToQuery();
   bcContact.SetSearchSpec("Last Name", "S*");
   bcContact.ExecuteQuery(ForwardBackward);
   TheApplication().GotoView("Contact List View", boGlobal);
function CmdBSGotoView(Inputs, Outputs)
   // Getting input arguments from Command Data parameters
   var number = Inputs.GetProperty("PhoneNumber");
   // Invoking Business Service "Communications Client" method
   var ctibs = TheApplication().GetService("Communications Client");
   ip.SetProperty("PhoneNumber", number);
   ip.SetProperty("ProfileName", "Siebel CTI");
   ctibs.InvokeMethod("MakeCall", ip, op);
Siebel CTI Administration Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
