Siebel CTI Administration Guide > Configuring User Interface Elements > Configuring Communications List of Values Types > List of Values Types for Event ParametersThis topic identifies List of Values types for parameters for event handlers, event responses, and event logs. NOTE: You must add List of Values records for these types only if you are using a custom communications driver. For more information about specifying events, see Defining Communications Events. List of Values Type for Event Handler ParametersIf you use a custom communications driver, then you require particular values to appear in the Name field (drop-down list) in the Event Handler Parameters applet. This applet appears in the All Event Handlers view, in the Administration - Communications screen. To specify your custom values, add or modify records for the List of Values type named COMM_EVTHNDLR_PARAM. List of Values Type for Event Response ParametersIf you use a custom communications driver, then you require particular values to appear in the Name field (drop-down list) in the Event Response Parameters applet. This applet appears in the All Event Responses view, in the Administration - Communications screen. To specify your custom values, add or modify records for the List of Values type named COMM_EVTRESP_PARAM. List of Values Type for Event Log ParametersIf you use a custom communications driver, then you require particular values to appear in the Name field (drop-down list) in the Event Log Parameters applet. This applet appears in the All Event Logs view, in the Administration - Communications screen. To specify your custom values, add or modify records for the List of Values type named COMM_EVTLOG_PARAM. |
| Siebel CTI Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
