Siebel CTI Administration Guide > Configuring User Interface Elements > Configuring Communications List of Values Types > List of Values Types for Command ParametersThis topic identifies List of Values types that parameters for commands and command data use. NOTE: You must add List of Values records for these types only if you are using a custom communications driver. For more information about specifying commands, see Defining Communications Commands. List of Values Type for Command ParametersIf you use a custom communications driver, then you require particular values to appear in the Name field (drop-down list) in the Command Parameters applet. This applet appears in the All Commands view, in the Administration - Communications screen. To specify your custom values, add or modify records for the List of Values type named COMM_CMD_PARAM. List of Values Type for Command Data ParametersIf you use a custom communications driver, then you require particular values to appear in the Name field (drop-down list) in the Command Data Parameters applet. This applet appears in the All Command Data view, in the Administration - Communications screen. To specify your custom values, add or modify records for the List of Values type named COMM_CMDDATA_PARAM. |
| Siebel CTI Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
