Siebel CTI Administration Guide > Configuring Events and Commands > Special Events for Device Events >
List of Special Events
The special events, which have names that start with the symbol @, are described in Table 7.
Table 7. Special Events
Event Name
Description
@PreIndicateNewWorkItemEvent
@PostIndicateNewWorkItemEvent
Respectively, these special events correspond to just before, and just after, the client handle method IndicateNewWorkItem is invoked. These special events have the following attributes:
  • ChannelType
  • ProfileName
  • WorkItemID
  • WorkItemMode
@PreWorkItemReleasedEvent
@PostWorkItemReleasedEvent
Respectively, these special events correspond to just before, and just after, the client handle method WorkItemReleased is invoked. These special events have the following attributes:
  • ChannelType
  • ProfileName
  • WorkItemID
@PreWorkItemResumedEvent
@PostWorkItemResumedEvent
Respectively, these special events correspond to just before, and just after, the client handle method WorkItemResumed is invoked. These special events have the following attributes:
  • ChannelType
  • ProfileName
  • WorkItemID
@PreWorkItemStartedEvent
@PostWorkItemStartedEvent
Respectively, these special events correspond to just before, and just after, the client handle method WorkItemStarted is invoked. These special events have the following attributes:
  • ChannelType
  • ProfileName
  • WorkItemID
@PreWorkItemSuspendedEvent
@PostWorkItemSuspendedEvent
Respectively, these special events correspond to when the client handle method WorkItemSuspended is invoked. These special events have the following attributes:
  • ChannelType
  • ProfileName
  • WorkItemID
@RuntimeEvent
Corresponds to a Siebel run-time event, which was defined in the Administration - Runtime Events screen. This special event has the following attributes:
  • Context. The business service context.
  • ActionSet. The name of the action set.
  • Action. The name of the action.
  • EventId. The ID of the run-time event.
  • Event Name. The name of the run-time event (for example, SetFieldvalue).
  • Sub Event. The name of the subevent.
  • Event Type. The event type specified in the Object Type field.
  • Object Name. The object name.
  • BusObjName. The business object name.
  • BusCompName. The business component name.
  • ActiveRowID. The current active row ID of the business component.
  • ViewName. The current view name.
For more information about configuring run-time events, see Siebel Personalization Administration Guide.
Siebel CTI Administration Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
