Siebel CTI Administration Guide > Configuring Events and Commands > Special Commands for Device Commands >
Special Command Parameters
Table 9 lists special command parameters and their usage. Table 8 identifies the commands that use each of these parameters. Within the communications configuration, special command parameters and values can be specified within command data definitions as subparameters of the Param parameter. For more information, see Command Data.
Table 9. Parameters for Special Commands
Command Parameter
Description
AppletMode
For @CreatePopupFrame, specifies the mode for an applet to be displayed in the new browser window.
Dimension
For @CreatePopupFrame, specifies the dimension of the new browser window.
PageURL
For @CreatePopupFrame, specifies a URL to be displayed in the new browser window.
SWECommand
For @InvokeSWECommand, specifies a Siebel Web Engine (SWE) command to be invoked.
View
For @ViewWorkObject, specifies the name of a view.
Siebel CTI Administration Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
