Siebel CTI Administration Guide > Configuring Events and Commands > Event Logs >
Event Log Parameters
Table 17 describes the parameters available in event logs. The value of the Macro column indicates whether macro expansion applies to the parameter.
Table 17. Event Log Parameters
AfterWork |
Group |
Yes |
Field names and values, from the log business component, that are used to update the work-tracking log record when the work item has ended or been released. NOTE: After the work item has been released, the log record that is modified according to the fields specified with this parameter is refreshed when the agent clicks off the record, then clicks on it again.
BusComp |
Char |
Not applicable |
Log business component name. |
BusObj |
Char |
Not applicable |
Log business object name. |
Display |
Boolean |
Not applicable |
Parameter that, when it is set to True and the current view contains a business component specified in the event log, uses the current business component to add a new log record. The log record appears on the screen immediately and is selected. In order for this parameter to function as intended, the current view must retain the focus. If Display is set to False, then the log record is generated but is not selected, and might not be displayed in the current record set. The default is False. NOTE: While the work item is active, the agent can modify the log record. After the work item has been released, however, if AfterWork is set, then an agent's changes might conflict with how the log record was written by the Siebel CRM system software at that time. The agent can click off the record, then click on it again to modify it.
LogField |
Group |
Yes |
Field names and values of the log business component. |
QuerySpec |
Char |
Yes |
A query specification for retrieving a record in the business component:
- If QuerySpec is not defined, then a new record is created for the event log.
- If QuerySpec is defined and returns a single record, then this record is used for the event log.
- If QuerySpec is defined and returns more than one record, then a new record is created for the event log.
ServiceMethod |
Char |
Not applicable |
The name of a Siebel business service and method to be called. The service and method are specified in the form service.method. Optionally, you can use the ServiceParam parameter to provide parameter names and values to pass to the method to be called. If ServiceMethod and ServiceParam are specified, then they are executed first when the event log is invoked. If the specified business service method does not return the required result, such as a value of True (1) for the output argument Continue, then the event log stops executing. For more information, see Using Business Services with Siebel Communications Server. |
ServiceParam |
Group |
Yes |
A group of subparameters that are parameters to the Siebel business service method (if any) invoked using the ServiceMethod parameter. You create each parameter that you need in the form ServiceParam.param_name, then specify a parameter value. The parameter name and value are both passed to the service method. Order parameters in the sequence in which they are expected by the service method: ServiceParam.Param1 = "value1" ServiceParam.Param2 = "name" Param1 and Param2 are subparameters of the ServiceParam parameter. For more information, see Using Business Services with Siebel Communications Server. |
WorkTrackingObj |
Group |
Yes |
Field name and values of a work-tracking object to create. You can retrieve the value of the tracking object from a command. For example, the following parameter defines a custom work-tracking object, called ContactId, whose value is derived from the Id field of the Contact business component. WorkTrackingObj.ContactId = "{Contact.Id}" For a selected work item, this data might then be accessed from a communications command, using the WorkTrackingObj command data parameter. In this example, ContactId becomes a custom work item attribute. Alternatively, if an event log includes a parameter definition like the following, then the text that you specify is displayed in the Work Items list in the communications toolbar. WorkTrackingObj.Description = "your descriptive text goes here" For more information about using these and other attributes, see Work Item Attributes. |
