Siebel CTI Administration Guide > Configuring Events and Commands > CommandsThis topic describes commands. It contains the following information: Commands in the communications configuration data define the appearance and availability of communications commands. By using the DeviceCommand parameter in a command, you can invoke a command on the communications system or invoke a special command.
Communications commands might instead invoke a business service method, a SmartScript, or a Siebel VB or Siebel eScript script. For commands, each of these mechanisms is mutually exclusive: invoke only one of these mechanisms in a given command. (Scripts and business service methods take precedence over device commands.) For more information:
| Siebel CTI Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
