Table 10. Settings for Configuring the SWSE Logical Profile
Setting in Siebel Configuration Wizard |
Parameter in eapps.cfg File |
Siebel Enterprise Name |
[/SiebelApp_lang] ConnectString |
Part of the ConnectString value represents the Siebel Enterprise name. |
Siebel Web Server Extension Logical Profile Name |
Not applicable |
By default, this location is the admin/Webserver directory under the home directory of the installed Siebel Enterprise Server component (such as Siebel Gateway Name Server). For example, for Siebel CRM version 15.0 on UNIX, the default SWSE logical profile location is /siebel/15.0.0.0.0/ses/gtwysrvr/admin/Webserver. You specify this location later when you configure the SWSE, as described in Applying the SWSE Logical Profile. |
Language for Server Messages and Logs |
[swe] Language |
The primary language, which is used for server messages and log files. Specify the same primary language that you selected when configuring the Siebel Enterprise Server software. See also Installing and Deploying Siebel Business Applications with Multiple Languages. NOTE: This option does not appear for a single-language installation. In this case, the installed language is used as the primary language.
Collect Application-Specific Statistics |
[swe] AllowStats |
Indicates whether to collect application-specific statistics. |
Compression Type |
Specify the type of compression to use for communications between the SWSE and the Siebel Servers. Part of the ConnectString value represents the compression type. Possible values are None or ZLIB. |
HTTP 1.1-Compliant Firewall / Enable Web Compression |
[defaults] DoCompression |
For more information, see Enabling HTTP Compression for Siebel Business Applications. |
Login Session Timeout Value |
[defaults] GuestSessionTimeout |
The total number of seconds that a guest session can remain inactive before the guest user is logged out and the session is closed. Default value: 300 (in seconds) |
Active Session Timeout Value |
[defaults] SessionTimeout |
The total number of seconds that a session can remain inactive before the user is logged out and the session is closed. Default value: 900 (in seconds) |
HTTP Port Number |
[defaults] HTTPPort |
Specify the port number that this Web server uses for Web browser connections. Default value: 80 |
HTTPS Port Number |
[defaults] HTTPSPort |
Specify the port number that this Web server uses for secure Web browser connections. Default value: 443 |
FQDN |
[defaults] EnableFQDN FQDN |
If you specify a fully qualified domain name, then the value is stored in the FQDN parameter, and EnableFQDN is set to TRUE. |
Employee User Login Name and Password |
[defaults] AnonUserName AnonPassword |
The Siebel user ID that starts the anonymous session from which an end user is shown the login page for an employee application. The employee applications use these parameters, which are defined in the [defaults] section. The EncryptedPassword parameter specifies whether passwords are encrypted in the eapps.cfg file. For more information about anonymous users, see Requirements for Configuring Anonymous Users for the Siebel Web Server Extension. |
Password Encryption |
[defaults] EncryptedPassword |
Specifies whether to encrypt all of the passwords stored in the eapps.cfg file. By default, EncryptedPassword is TRUE. For more information about managing encrypted passwords, see Siebel Security Guide. |
Contact User Login Name and Password |
[/SiebelApp_lang] AnonUserName AnonPassword |
The Siebel user ID that starts the anonymous session from which an end user is shown the login page for a customer application. This anonymous user must have access to any public view in the Siebel application. For customer applications only, these parameters are defined in application-specific sections of the eapps.cfg file. These values override the values defined in the [defaults] section, which are used by employee applications. The EncryptedPassword parameter specifies whether passwords are encrypted in the eapps.cfg file. For more information about anonymous users, see Requirements for Configuring Anonymous Users for the Siebel Web Server Extension. |
Siebel Enterprise Security Token |
[/SiebelApp_lang] SiebEntTrustToken |
A password that is used to update static files on the Web server. The EncryptedPassword parameter specifies whether passwords are encrypted in the eapps.cfg file. For more information about this token, see About the Siebel Enterprise Security Token. |
Web Server-Specific Statistics: Default Statistics Page for Web Server |
[defaults] statspage |
The default value is _stats.swe. It is recommended that you change the default value, so that the Web server statistics are saved into a different file name. |
Select the Connection Protocol and Encryption |
Not applicable |
Specify if you are using TLS (Transport Layer Security) for communication between Siebel Servers and the SWSE. Choices are TCP/IP (no encryption, the default) or TLS. TLS settings for SWSE must be compatible with those for Siebel Servers that connect to this Web server. The wizard prompts for remaining parameters related to TLS only if you select one of these options. For more information about TLS and the related parameters defined in the [ConnMgmt] section of the eapps.cfg file, see Siebel Security Guide. |
Deploy TLS in the Enterprise |
Not applicable |
Specify if you are using TLS (Transport Layer Security) for communication between Siebel Servers and the SWSE. |
Certificate File Name |
[ConnMgmt] CertFileName |
For more information, see Siebel Security Guide. |
Certification Authority (CA) Certificate File Name |
[ConnMgmt] CACertFileName |
Private Key File Name and Password |
[ConnMgmt] KeyFileName KeyFilePassword |
Enable Peer Authentication |
[ConnMgmt] PeerAuth |
Validate Peer Authentication |
[ConnMgmt] PeerCertValidation |
