Siebel Installation Guide for UNIX > Installing Siebel Enterprise Server Components and the Siebel Web Server Extension > Installing the Siebel Web Server ExtensionThis topic provides instructions for installing the Siebel Web Server Extension (SWSE) on your Web server computer, using the GUI installation method, as part of standard Siebel Business Applications deployment. NOTE: This topic includes instructions for installing the SWSE as a new installation or as a migration installation. For an existing installation, you perform a migration installation instead of a new installation. The installation program sets up the Siebel directory structures and copies the required files and components to the target location on the Web server. If you are installing from a remote computer, or using X-connectivity software to access a UNIX computer from a Windows computer, then see also Installing Siebel Business Applications from a Remote Server Computer. The SWSE installer verifies that you have the required software at the necessary version levels for installing Siebel Business Applications software. This topic contains the following information:
Related TopicsRelated Books |
| Siebel Installation Guide for UNIX | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
