Siebel Installation Guide for Microsoft Windows > Configuring Siebel Enterprise Server Components and the Siebel Web Server Extension > More Information About Using the Siebel Configuration Wizards >
Options for Configuring the Siebel Server
Running the Siebel Server Configuration Wizard assumes that you have performed all of the prerequisite configuration tasks: configuring the Siebel Gateway Name Server, Siebel Enterprise, and SWSE logical profile; and installing the Siebel database. This topic is part of More Information About Using the Siebel Configuration Wizards.
After you have installed Siebel Server and performed the prerequisite tasks, you run the Siebel Server Configuration Wizard to perform the Create New Configuration task as shown. This wizard includes the following tasks.
After you have already configured a Siebel Server, you can modify the Siebel Server configuration using Siebel Server Manager, as described in Siebel System Administration Guide.
  • Create New Configuration. Creates a new Siebel Server configuration. The configuration information is stored on the Siebel Gateway Name Server. For more information about these settings, see Configuring the Siebel Server.
    NOTE:  Before you perform this task, the Siebel Gateway Name Server must have already been installed and configured, and must be running, unless you run the wizard with the flag to skip validation.
  • Add Language Support for the Siebel Server. Deploys any additional installed languages for a Siebel Server that you previously configured. This task applies only if both of the following are true:
    • You have already initially configured the Siebel Server (Create New Configuration task).
    • You have already installed on the Siebel Server the new languages that you want to add as deployed languages.
      In the screen where you specify languages to deploy, specify only the new languages that you want to deploy. See also Configuring the Siebel Server.
      Perform this task in conjunction with related language deployment tasks, such as to install and deploy languages on the SWSE. For more information, see Installing and Deploying Siebel Business Applications with Multiple Languages.
      NOTE:  Before you perform this task, the Siebel Gateway Name Server must have already been installed and configured, and must be running, unless you run the wizard with the flag to skip validation. The Siebel Server configuration that you are modifying must already exist.
      NOTE:  If you add (install) languages before you have configured the Siebel Server, then do not perform this task. Instead, use the task Create New Configuration, and specify all of the applicable languages that you want to deploy on this Siebel Server.
Siebel Installation Guide for Microsoft Windows Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
