Siebel Installation Guide for Microsoft Windows > Configuring Siebel Enterprise Server Components and the Siebel Web Server Extension > More Information About Using the Siebel Configuration Wizards >
Options for Configuring the Siebel Gateway Name Server, the Siebel Enterprise, and the SWSE Logical Profile
After you install Siebel Gateway Name Server (using the Siebel Enterprise Server installer), you run the Siebel Configuration Wizard (Siebel Enterprise Configuration). This wizard includes the following tasks. Perform the tasks under Create New Configuration in the order shown. This topic is part of More Information About Using the Siebel Configuration Wizards.
- Create New Configuration
- Configure a New Gateway Name Server. Configures the Siebel Gateway Name Server that you have installed. For more information about these settings, see Configuring the Siebel Gateway Name Server.
- Configure a New Enterprise in a Gateway Name Server. Creates a new Siebel Enterprise configuration. The configuration is stored on the Siebel Gateway Name Server. For more information about these settings, see Configuring the Siebel Enterprise.
NOTE: Before you perform this task, the Siebel Gateway Name Server must have already been installed and configured, and must be running, unless you run the wizard with the flag to skip validation.
- Configure a New Siebel Web Server Extension Logical Profile. Creates and saves an SWSE logical profile in a location that you designate. The logical profile stores settings that might apply to one or multiple SWSE installations. The logical profile also includes editable files that automatically create the Siebel application virtual directories on the Web server when you apply the SWSE logical profile.
When you configure an installed instance of SWSE, you apply an SWSE logical profile. This task updates the eapps.cfg file on the SWSE with settings from the SWSE logical profile and other settings specific to this SWSE instance. It also creates the virtual directories on the Web server. For more information about creating and applying the SWSE logical profile, see Process of Configuring the Siebel Web Server Extension.
- Modify Existing Configuration
- Modify an Existing Enterprise. Modifies the configuration settings for a Siebel Enterprise that you previously configured. For more information about these settings, see Configuring the Siebel Enterprise.
NOTE: Before you perform this task, the Siebel Gateway Name Server must have already been installed and configured, and must be running, unless you run the wizard with the flag to skip validation. The Siebel Enterprise configuration that you are modifying must already exist.
Alternatively, you can modify the configuration settings for an existing Siebel Enterprise by using Siebel Server Manager, as described in Siebel System Administration Guide.
