Table 8. Settings for Configuring the Siebel Enterprise
Setting in Siebel Configuration Wizard (Parameter) |
Gateway Name Server Authentication User Account Name |
Specify the user name for the account, usually a database account, that you are using for Siebel Gateway Name Server authentication. For more information about this account and the associated requirements, see Requirements for Siebel Gateway Name Server Authentication. NOTE: The first time that you configure a Siebel Enterprise (before authentication settings have been propagated to the Siebel Gateway Name Server), the user account name and password fields have no effect.
Gateway Name Server Authentication User Account Password |
Specify the password for the account that you are using for Siebel Gateway Name Server authentication. |
Gateway Name Server Host Name |
Specify the host name of the computer on which the Siebel Gateway Name Server is installed. For more information, see Restrictions on Host Names for Siebel Gateway Name Server and Siebel Server. |
Gateway Name Server TCP/IP Port |
Specify the port number that the Siebel Gateway Name Server uses for connections from Siebel Server or other components. The default port number is 2320. Use the port number that you specified when you configured the Siebel Gateway Name Server. |
Siebel Enterprise Name |
Specify the name that you want for the Siebel Enterprise. For more information, see Restrictions on Names for Siebel Enterprise and Siebel Server. |
Enterprise Description (EnterpriseDesc) |
Provide a short description for the Siebel Enterprise. |
Primary Siebel File System (FileSystem) |
Specify the location or locations of the Siebel File System. For more information, see Creating the Siebel File System. |
Database Platform |
The RDBMS options for the Siebel database are:
- Oracle Database Enterprise Edition
- IBM DB2 UDB for Linux UNIX Windows
- IBM DB2 UDB for z/OS
- Microsoft SQL Server
Microsoft SQL Server Host Name |
(Microsoft SQL Server only) |
Microsoft SQL Server Database Name |
Database Table Owner (TableOwner) |
(Oracle Database, DB2, or DB2 for z/OS only) |
IBM DB2 Database Alias |
(DB2 only) |
Current IBM DB2 SQL ID / Group Name |
(DB2 for z/OS only) |
Oracle SQLNet Connect String |
(Oracle Database only) |
Siebel Database User Account Name |
(For all database platforms) |
Siebel Database User Account Password |
Enterprise Security Authentication Profile |
The options are:
- Database Authentication (default). Corresponds to SecAdptMode parameter value DB.
- Lightweight Directory Access Protocol (LDAP) Authentication. Corresponds to SecAdptMode parameter value LDAP.
- Custom Security Authentication, using the Security SDK. Corresponds to SecAdptMode parameter value CUSTOM.
- Active Directory (ADSI) Authentication (Windows only). Corresponds to SecAdptMode parameter value ADSI.
Database authentication is enabled by default. After you configure a different security adapter, that adapter is not yet enabled for use. If you enable a security adapter after configuring it, then manually set the parameter SecAdptMode using one of the listed values. For example, do so for an Application Object Manager component for which you are enabling a security adapter, such as the security adapter for LDAP. NOTE: Although database authentication is supported for development environments only, it is strongly recommended that you keep database authentication enabled for the Siebel Enterprise. As applicable for your deployment, enable any non-database security adapter for individual servers or components only, using Server Manager.
If, later in the same Configuration Wizard session, you select the option Propagate Authentication Settings to the Gateway Name Server, then the settings are also propagated for Siebel Gateway Name Server authentication. For more information, see Requirements for Siebel Gateway Name Server Authentication. For more information about all of the authentication options, see Siebel Security Guide. |
Security Adapter Name (named subsystem) |
In general, it is recommended that you accept the default security adapter name. The default name depends on the type of security adapter that you are configuring. Default names are as follows:
- DBSecAdpt
- LDAPSecAdpt
- CUSTOMSecAdpt
- ADSISecAdpt
If you enable a security adapter after configuring it, then manually set the parameter SecAdptName to the same name. For example, do so for an Application Object Manager component for which you are enabling a security adapter, such as the security adapter for LDAP. For more information about all of the authentication options, see Siebel Security Guide. |
Security Authentication Library CRC Checksum (CRC) |
LDAP, ADSI, or custom authentication only. NOTE: This option does not apply to database authentication. The same is true for all of the remaining authentication settings, except those for Siebel Gateway Name Server authentication.
Directory Server Domain Name (ServerName) |
LDAP or ADSI authentication only. |
LDAP Port Configuration (Port) |
LDAP authentication only. The default port numbers are 389 or 636 (secure). |
Network TCP/IP Port Number (Port) |
LDAP authentication only. |
Siebel Username Attribute (UsernameAttributeType) |
Siebel Password Attribute (PasswordAttributeType) |
Credentials Attribute (CredentialsAttributeType) |
LDAP, ADSI, or custom authentication only. |
LDAP Roles Attribute (optional) (RolesAttributeType) |
Shared Database Account Distinguished Name (SharedCredentialsDN) |
Store shared database user credentials as parameters |
Shared Database Account |
Shared Database Account Password |
Siebel Application Distinguished Name (DN) (ApplicationUser) |
Application Password (ApplicationPassword) |
Configure Web Single Sign-On (Web SSO) (SingleSignOn) |
User Specification (UserSpec) |
Shared Secret (TrustToken) |
TLS Database Certificate File (SslDatabase) |
Hash User Passwords (HashUserPwd) |
Hash Database Passwords (HashDBPwd) |
Salt User Passwords (SaltUserPwd) |
Salt Attribute (SaltAttributeType) |
Security Adapter Mapped User Name (UseAdapterUserName) |
Siebel User ID Attribute (SiebelUsernameAttributeType) |
Base Distinguished Name (DN) (BaseDN) |
Propagate Change (PropagateChange) |
Propagate Authentication Settings to the Gateway Name Server |
Select this option to propagate authentication settings that you made to the Siebel Gateway Name Server. NOTE: The first time that you specify the Siebel Gateway Name Server authentication settings at the start of the task, you must select this check box. Subsequently, select this box only when you are changing existing settings.
Microsoft SQL Server Port Number |
(Microsoft SQL Server only) This option appears only when database authentication for Siebel Gateway Name Server authentication is used, and you are propagating authentication settings to the Siebel Gateway Name Server. |
Additional Tasks for Configuring the Enterprise |
The items listed represent categories of additional optional selections for creating a new Siebel Enterprise.
- Enterprise Network Security Encryption Type
- Charts Server Settings
- Data Quality Products and Connectors
Tasks for Modifying Enterprise Configurations |
The items listed represent categories of optional selections for modifying an existing Siebel Enterprise.
- Enterprise Security Authentication Default
Charts Server Host Name (DSChartServer) |
Appears only if you selected Charts Server Settings in a prior screen. Specify the host name and the port number of the computer where you are running the Siebel Charts server. Use the format Charts_server_hostname:port_number. See Changing the Siebel Charts Server Used by Siebel Web Clients. |
Chart Image Format (DSChartImageFormat) |
Appears only if you selected Charts Server Settings in a prior screen. Choose png (the default), jpg, or gif. Accepting the default is recommended. The value must be in lower case. See Changing the Siebel Charts Server Used by Siebel Web Clients. |
Siebel Data Quality Matching |
Appears only if you selected Data Quality Products and Connectors in a prior screen. Choose None or Siebel Data Quality Connector. |
Security Encryption Level or Type (Crypt and ConnType) |
This setting and all of the remaining items appear only if you selected Enterprise Network Security Encryption Type in a prior screen. Options are:
- SISNAPI Without Encryption
- SISNAPI Using RSA Encryption Algorithm
- SISNAPI Using TLS 1.2
- SISNAPI Using Microsoft Crypto Enhanced API Encryption
Certificate File Name (CertFileName) |
This item and all of the remaining items appear only if you selected one of the TLS options in Security Encryption Level or Type. For more information, see Siebel Security Guide. |
Certificate Authority (CA) Certificate File Name (CACertFileName) |
Private Key File Name (KeyFileName) |
Private Key File Password (KeyFilePassword) |
Enable Peer Authentication (PeerAuth) |
Validate Peer Certificate (PeerCertValidation) |
