Table 9. Settings for Configuring the Siebel Server
Setting in Siebel Configuration Wizard (Parameter) |
Gateway Name Server Authentication User Account Name |
Specify the user name for the account that you are using for Siebel Gateway Name Server authentication. |
Gateway Name Server Authentication User Account Password |
Specify the password for the account that you are using for Siebel Gateway Name Server authentication. |
Gateway Name Server Host Name |
Specify the host name of the computer on which the Siebel Gateway Name Server is installed. |
Gateway Name Server TCP/IP Port |
Specify the port number that the Siebel Gateway Name Server uses for connections from Siebel Server or other components. The default port number is 2320. Use the port number that you specified when you configured the Siebel Gateway Name Server. |
Siebel Enterprise Name |
Specify the name of the Siebel Enterprise that you previously configured. |
Siebel Server Name (Server) |
Represents the name of the Siebel Server configuration instance, as it is stored in the Siebel Gateway Name Server. For more information, see Restrictions on Names for Siebel Enterprise and Siebel Server. |
Siebel Server Description (ServerDesc) |
Provide a short description for the Siebel Server. |
Enable Component Groups |
Specify one or more component groups to enable for this Siebel Server. For more information about component groups, see Siebel System Administration Guide. |
Specify Client User Interface (EnableOpenUI) |
Specify the client user interface for Siebel applications on this Siebel Server. Select one of the following options:
- Open UI
- High Interactivity
Your selection sets the parameter EnableOpenUI to True (for Siebel Open UI) or to False (for high interactivity) for the Application Object Managers in the component groups that you are enabling on this Siebel Server. For more information, see Enabling Siebel Open UI. |
Language for Server Messages and Logs (Lang) |
The primary language, which is used for server messages and log files. Language support must be present on the server on which you have installed the software. See also Installing and Deploying Siebel Business Applications with Multiple Languages. NOTE: This option does not appear for a single-language installation. In this case, the installed language is used as the primary language.
Deployed Languages |
Specifies the installed languages that you want to deploy. Application Object Manager components are created for each of these languages. NOTE: This option does not appear for a single-language installation. In this case, the installed language is automatically deployed when you configure the Siebel Server.
After initially configuring the Siebel Server, you can deploy languages that you installed but did not deploy by running the Siebel Server Configuration Wizard again and choosing the task Add Language Support for the Siebel Server. For more information, see Installing and Deploying Siebel Business Applications with Multiple Languages and Enabling and Disabling Language-Specific Application Object Managers and Adding Languages. |
Siebel Connection Broker Port (PortNumber) |
Specify the TCP/IP port number for the Siebel Connection Broker component (alias SCBroker). The default port number is 2321. NOTE: This port number is used for all of the communications between SCBroker and other components, including the Web server and SWSE. Make sure that the port number that you specify for SCBroker is not occupied by any other applications, other Siebel components (such as Siebel Gateway Name Server), or other Siebel Server instances. You also specify this port number when you configure the SWSE, as described in Applying the SWSE Logical Profile.
For more information about the SCBroker component, see Siebel Deployment Planning Guide and Siebel System Administration Guide. If you want to change an SCBroker port number later, then use Siebel Server Manager to specify a value for the Static Port Number parameter (alias PortNumber). |
Network TCP/IP Port for Synchronization Manager (SyncPort) |
Specify the TCP/IP port number for the Synchronization Manager component, which is part of Siebel Remote. The default port number is 40400. |
Additional Tasks for Configuring the Siebel Server |
Specify subtasks for additional configuration of the Siebel Server. Options include:
- Server-Specific Security Encryption Settings. Use this task to configure TLS communications between this Siebel Server and other servers.
- Server-Specific Security Authentication Profile Assignment. Use this task to assign an existing security adapter to this Siebel Server or to specific components.
Certificate File Name (CertFileName) |
For the Server-Specific Security Encryption Settings task. |
Certificate Authority (CA) Certificate File Name (CACertFileName) |
Private Key File Name (KeyFileName) |
Security Adapter Name (SecAdptName and SecAdptMode) |
For the Server-Specific Security Authentication Profile Assignment task. Specify the existing security adapter you are assigning to this Siebel Server or to individual server components. |
Security Authentication Scope for Server |
For the Server-Specific Security Authentication Profile Assignment task. Options are:
- Set this configuration for the entire Siebel Server (server level)
- Set this configuration for specific Object Managers (component level)
Select Object Managers for Security Adapter |
For the Server-Specific Security Authentication Profile Assignment task. The option appears if you specify that you want to configure security for individual Application Object Managers or other server components. Optionally, use Server Manager for this purpose. |
Clustering Configuration |
Clustering options include:
- Clustered using virtual host name
- Clustered using virtual IP address
- Not clustered
Siebel Server Cluster Virtual Host Name/IP |
This option appears if you chose either of the two clustering options. |
Siebel Server Cluster Virtual Host Name |
This option appears if you chose the first clustering option (Clustered using virtual host name). |
Siebel Server Cluster Virtual IP |
This option appears if you chose the second clustering option (Clustered using virtual IP address). |
Autostart Siebel Server System Service |
Specify whether to start the Siebel Server when Windows starts. |
Start Siebel Server System Service During Configuration |
Specify whether to start the Siebel Server system service after the configuration has successfully executed. NOTE: After configuring the Siebel Server, it is still necessary to restart the Siebel Server manually for your configuration selections to take effect.
