Siebel Installation Guide for Microsoft Windows > Installing Siebel Charts > About Installing Siebel ChartsSiebel Charts, which uses the third-party product NetCharts Server from Visual Mining, provides functionality for generating and displaying charts in Siebel Business Applications. Siebel Charts configuration is part of installation. You specify configuration-related information in the installer before files are copied to the target computer. TIP: Optionally, you can use jQuery Charts instead of NetCharts Server, for deployments using Siebel Open UI. For more information, see Enabling jQuery Charts. For general requirements for Siebel Charts, see Requirements for Installing and Configuring Siebel Business Applications. See also the NetCharts Server Installation Guide by Visual Mining, Inc., on the Siebel Business Applications Third-Party Bookshelf in the product media pack on Oracle Software Delivery Cloud. You can install Siebel Charts on any server computer that your Siebel Servers can connect to through HTTP. Typically, it is installed on a Siebel Server computer. If Siebel Charts is not installed on a Siebel Server computer, then install it on the same subnet as the Siebel Servers. No additional license key is required for Siebel Charts. NOTE: This topic supplements the installation instructions provided by Visual Mining, Inc., which are provided in the Siebel Business Applications Third-Party Bookshelf in the product media pack on Oracle Software Delivery Cloud. It is not intended to replace them. Default Ports Used by Siebel ChartsThe Siebel Charts server requires that certain ports be available. If these ports are used by any other application, then the Charts server will not start correctly. Siebel Charts uses the following ports by default:
| Siebel Installation Guide for Microsoft Windows | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
