Siebel Installation Guide for Microsoft Windows > Installing Siebel Charts >
Siebel Charts software is installed with the Siebel Mobile Web Client and Developer Web Client. The associated Windows service starts automatically when a chart is accessed within the Siebel Web Client. This task is a step in:
NOTE: As of Siebel Innovation Pack 2015, this procedure includes steps that apply a patch that provides Tomcat updates to mitigate security vulnerabilities.
To install Siebel Charts
- Review the information in About Installing Siebel Charts.
- In Windows Explorer, navigate to the Siebel image location for the current release. Then navigate to the directory where the installer is located. Navigate to
Siebel_Image\Windows\Server_Ancillary\Visual_Mining_Netcharts_Server\lang\windows.
where:
- Siebel_Image is the directory for your version-specific Siebel network image, such as
C:\Siebel_Install_Image\15.0.0.0.
- lang is the three-letter code for the language of your Siebel Business Applications; for example,
enu for U.S. English.
- To start the NetCharts Server installer, double-click NetChartsServer4.6SiebelEdition.exe.
- As you proceed from screen to screen using the installer, accept all of the applicable defaults, and accept all of the license agreements.
- Perform the following steps to complete installation for Microsoft Windows. These steps apply a patch that provides Tomcat updates to mitigate security vulnerabilities.
- From the directory noted in Step 2, from which you ran the NetCharts Server installer, copy the file NCS1625.zip to the computer where you are installing NetCharts Server.
- Uncompress NCS1625.zip.
- In the NCS1625 directory, follow the directions in the file README.htm.
- Restart your computer.
